Message 1 of 5
HH3 Manager
Anybody know why I can’t get Hub Manager on my iPhone. It was fine with HH2?
It just says “Safari can’t open the page because the Server can’t be found”.
4 REPLIES 4
Message 2 of 5
Re: HH3 Manager
Must be an Apple thing, works just fine with Firefox on Android.
Try with Firefox rather than Safari.
Message 3 of 5
Re: HH3 Manager
Downloaded Firefox onto iPhone and it worked. Thanks.
Message 4 of 5
Re: HH3 Manager
Apple strikes yet again 😂😂
Message 5 of 5
Re: HH3 Manager
@licquorice  For benefit of others I’ve fixed the problem on the iPhone and can now access the Hub Manager using Safari.
solution: you need to go into WiFi settings and click on the Hub SSID and switch off “Private WiFi Address”
