Message 1 of 4
Home Hub 4
Can I connect a scanner to the usb port on my home hub 4 router, to be available aross my home network?
3 REPLIES 3
Message 2 of 4
Re: Home Hub 4
Can I connect a scanner to the usb port on my home hub 4 router, to be available across my home network?
@MalcHill The USB port only supports storage devices like memory sticks and small hard drives, so its not possible to connect a scanner.
Message 3 of 4
Re: Home Hub 4
No. It won't work because the HH4 does not have a printer server capability to drive your scanner.
Message 4 of 4
Re: Home Hub 4
Thanks. Useful to know, if not what I had hoped
