Message 1 of 6
Home WiFi white discs lost connection
My 4 white discs were working fine for ages then one changed to a red light. Tried rebooting disc, still red; rebooted router, no change; tried adding it as a new disc and it showed blue light while connected by cable but red once on wireless; tried same after resetting to factory settings with same result - plus the other 2 that were working wirelessly are showing red lights too!
Can anyone advise what else to try with this please? I saw one post suggesting not using the app but connecting to the disc in the router but I can't see how to do that.
Any help appreciated.
5 REPLIES 5
Message 2 of 6
Re: Home WiFi white discs lost connection
@DavidW32
Welcome to this user forum for BT Retail Broadband and phone customers.
It would be best to give the WHW product helpdesk a call on 0808 100 6116 ( Mon to Fri 9am to 5.30pm and Sat 9am to 2pm) or drop them an email to: [email protected] and they'll be happy to help.
Message 3 of 6
Thanks Keith.
They aren't open on Bank holidays so I'll do that next week.
Message 4 of 6
Hi @DavidW32 and thanks for posting.
Sorry for the late reply. Did you contact the helpdesk? Were they able to help?
Cheers
David
Message 5 of 6
Yes, sorry, should have replied earlier.
Help desk did help (when I eventually talked to someone) and got 3 working, confirming that 1 is not functioning properly. Unfortunately this had to be done by resetting all the discs (I'd only tried resetting 2) which meant I then had to set up my own SSID again. Worth it though!
Thanks again.
Message 6 of 6
Thanks for getting back to us @DavidW32.
I'm sorry about the trouble you had to get it sorted but it's great to see that 3 of them are working.
DanielS
