Message 1 of 2
How can I get a hub replaced by BT...?
Hi guys!
I've had my hub since the v2 was first launched but it keeps cutting of and disconnecting. I've read that BT own the hubs?? 🤷‍♂️ anyway if they own them, is it possible to have BT replace it?
Many thanks
1 REPLY 1
Message 2 of 2
Re: How can I get a hub replaced by BT...?
@Sgmckelvey
Which home hub do you have at the moment, and what type of broadband connection do you have?
If the broadband is cutting out, its more  likely to be a noisy phone line.
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
If you are still in a contract, then BT will replace the home hub for free, if its the cause of the problem.
