Message 1 of 1
How to remove stand from BT Whole Home WiFi device
If you remove the plastic plate that slides out of the back there's a mounting hole, but I can't get it to sit flush on the wall without removing the stand. Does anyone know how?
Edit: nevermind, figured it out. You have to pry off the cover and undo a screw. But, it's pointless as there needs to be clearance for power and ethernet cables anyway.
