Message 1 of 4
Hybrid Connect
Can anyone tell my do BT have a policy for the Hybrid Speed Boost stating a minimum 4g connection speed, I cannot find anything but being told it has to be 3bars.
when reading this forum lots of people seem to be using with only 2bars
any help greatly appreciated
3 REPLIES 3
Message 2 of 4
Re: Hybrid Connect
Hi @Harpia
As far as I can see Hybrid Speed Boost is a business product and has nothing to do with Halo 3+ Hybrid Connect for consumer users.
Two or three bars on consumer Hybrid Connect doesn’t make any difference in speeds, which is set at 30 mbps.
https://btbusiness.custhelp.com/app/answers/detail/a_id/55279/~/help-with-hybrid-speed-boost
Message 3 of 4
Re: Hybrid Connect
Yes I have a business account with BT, and they are telling that I must have a 3bar 4g signal. and according to BT i get no EE signal, but actually I get a 2 bar signal with an EE sim.
but they are refusing to provide the hybrid booster. I get 4mbs on copper as I live rurally, and this speed boost would help a lot.
I also wonder does it have to be EE can I use another network.
Message 4 of 4
Re: Hybrid Connect
This is the residential forum, you need to post on the business forum.
https://business.forums.bt.com/
