Message 1 of 7
Hybrid Connect
Can anyone tell me what mobile frequency the Hybrid device uses and what mobile signal strength is needed as a minimum for connection strength. apparently, it doesn't use the 800mhz as standard EE devices do.
my understanding is that both the copper and mobile signal must be comparable for it to work
Tags (1)
6 REPLIES 6
Message 2 of 7
Re: Hybrid Connect
@Harpia The radio transmission info is on the back page of the Hybrid connect userguide
I hope that helps?
Neil
Tags (1)
Message 3 of 7
Re: Hybrid Connect
Thanks,
Had a read doesn't state anywhere that you have to have minimum connection speed or what 4g rang it uses.
Tags (1)
Message 4 of 7
Re: Hybrid Connect
It gives the 4G bands at the bottom of the table.
LTE Bands 1/3/7/20/38
800Mhz is band 20
Tags (1)
Message 5 of 7
Re: Hybrid Connect
Have a look at this thread https://community.bt.com/t5/BT-Devices/Hybrid-Connect-attaching-additional-antennas/td-p/2141062
In particular message 9 shows receiver sensitivity figures.
Tags (1)
Message 6 of 7
Re: Hybrid Connect
Thanks for the additional information very useful.
Tags (1)
Message 7 of 7
Re: Hybrid Connect
Thanks, do you happen to know does the Hybrid Speed boost need a minimum 4g signal. I'm told BT policy is 3 bars however I cannot find this stated anywhere
Any help or information would be greatly appriciated
Tags (1)
