Message 1 of 5
Hybrid Connect
I have a new BT Hybrid Connect. By the hub it gets no signal. I have tried it in various places around the house as per instructions on its set-up guidance leaflet.  At best it only shows one blue bar showing therefore a poor signal, whereas my phone (using Vodafone) has a very strong signal. Any ideas for how this can be improved or am I stuck with a poor bit of equipment?
4 REPLIES 4
Message 2 of 5
Re: Hybrid Connect
the BT hybrid connect relies on a good EE/BT mobile signal to connect to internet.  did you not check you had a good signal before adding the hybrid connect to your package?
Message 3 of 5
Re: Hybrid Connect
The thought never entered my mind, and being a not very clever person when it comes to technology I would not have known how to do it had I thought of it.
Message 4 of 5
Re: Hybrid Connect
easily found using google
https://www.ofcom.org.uk/mobile-coverage-checker
Message 5 of 5
Re: Hybrid Connect
Thanks for this. Looks like I am stuck with the problem.
