Message 1 of 6
Hybrid connect variants
I received my HC box today and the faceplate is EE instead of BT. Interested to see are there variants of this box? Are they now issuing EE branded boxes as a matter of course now..
5 REPLIES 5
Message 2 of 6
Re: Hybrid connect variants
BT use the EE network.
Message 3 of 6
Hi @Kielty23   If it had BT on the front then it would have been an old box. The current boxes have EE.
Message 4 of 6
Thanks all, much appreciated
Message 5 of 6
So does that mean as they are moving everyone at sometime over to EE
I will be sent a new hybrid box with a EE Sim instead of the BT one
Anonymous
Not applicable
Message 6 of 6
All retail customers (e.g. the likes of you and me), are being moved over time to the consumer brand of EE apart from a small group of broadband customers who will stay with BT.
Nothing much will change and I don’t suspect any business could afford to replace all the kit branded in one flavour with another in one go, so I suspect you will get more EE branded stuff as new products are developed and you change contracts or as faulty equipment is replaced.
