Message 1 of 4
Hybrid connect.
How does EE Hybrid connect work with PC and laptop? When my broadband drops there’s no connection showing for EE.
3 REPLIES 3
Message 2 of 4
Re: Hybrid connect.
Hi @Jar34   The Hybrid Connect is a modem add on for your SH2 router. You simply connect your laptop to the router as normal.
Message 3 of 4
Re: Hybrid connect.
The idea is that you don't have to do anything.  The main router will "transparently" switch from using its regular internet connection to using the Mobile connection from the hybrid connect.
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 4 of 4
Re: Hybrid connect.
Thank you for your reply.
