Message 11 of 14
Re: Network failure on Smart Hub 2
Thanks Keith, I'll give that a try.
Message 12 of 14
PS. Before the Smarthub update, I've had 2 pairs of powerline adapters in use, both connected directly to separate hub Ethernet ports. The new hub just doesn't like it.
Message 13 of 14
The HomeAV standards do indeed allow you to have more than one set of powerline adapters in use on the same mains circuit at a time.  They need to have different passwords and the performance is usually atrocious, but it will work!  Obviously, you can have multiple powerline adapters in a set, but even then with HomeAV and HomeAV2 beyond 4 units, the performance falls through the floor!
While I've used Ghn (Devolo) powerline adapters I've never seen more than a single set in use at a time with these.
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 14 of 14
WAN Port now Ethernet. Thanks. Still have not resolved using 2 pairs of powerline adapters. Gave up in the end and got a WiFi disc (a free extra included in the BT Package).
