Message 1 of 1
Original Whole Home discs suddenly giving error 42
I have 3 of the original (white) Whole Home discs, which have worked fine until today.  I am actually only using 2.
Suddenly, after a power outage, the second disc (not directly connected to the modem) started showing a red light and the app shows it offline.
I ended up 'removing' the disc and adding at anew.  The app says it has found the new disc but then reports error-42.
I tried the 3rd disc which was not currently in use.  That also shows error-42
I have not had to make any changes for years but used not to have any problems when I needed to.  Nasty feeling the app has been updated and does not play well with the original discs?
Help please.  I am reduced to just the one disc connected to the modem.
