Message 11 of 20
Re: Plugging wireless access point into whole home disc
I use the ethernet port on one of my Wholehome white disks as an output, providing broadband to a TV and a satellite box via an ethernet switch. This works just fine, so it's difficult to understand why the OP's connection doesn't work. The only difference I can see is the distance between the white disk and the ethernet connected units, but this shouldn't adversely affect the connection, assuming a decent ethernet cable.
One thing the OP could try would be to get a new Cat5e or 6 ethernet cable and try that to see if it works
Message 12 of 20
Have plugged a "short" Ethernet cable into the disk that you are using to see if you are getting a connection to that disk before connecting the shed cable to it?
Have you checked the cable from the house to the shed is wired/working correctly using a Network Cable Tester?
Message 13 of 20
I have connected it all up indoors, to rule out the long run of cat 6. Had the ap directly connected to a disc in the house
Message 14 of 20
Ok, have you tried a factory reset of the AP?
Message 15 of 20
Yup
Message 16 of 20
Out of ideas now I'm afraid
Message 17 of 20
I may have missed it if you have but have you connected the WAP to your router directly with a known good Ethernet cable and made a connection to the WAP without involving any discs?
Message 18 of 20
Sorry, I should have already said this, but yes I have, tried to rule out all the factors first
Message 19 of 20
I am still not clear, have you checked the disc that you are using to connect the shed is actually working when you connect an Ethernet cable to it. ie have you plugged a laptop into a known working Ethernet cable connected to the disc and made an Internet connection?
If that works and you say the AP apparently works the only thing left is the Cat6 cable.
Message 20 of 20
Yes the discs all work and the ethernet point works with other devices. I think it's definitely some kind of networking clash....not sure if a wireless access point can be connected via a disc
