I have just switched to ee and need to return my BT router. It's new in the last year. ee said they would send a Royal Mail label but they didn't. Don't want to be stung for £65 but equally don't have the hours needed to ring bt or ee to get a label sent! Any advice? Thank you.
Solved! Go to Solution.
You've listed the only 2 options open to you. Your choice as to which you decide to go with.
If you call BT 0330.1234.150 you can request that they send one out to you.
Make sure you keep a copy of your Proof of Posting and if possible take a photograph of it in case you somehow lose the paper copy.
Failing that just keep the router and when you get the bill reflect on why you didn't do as you obviously know what you should have done!
Bit confused why EE would offer to send a returns label as EE have absolutely nothing to do with the BT router's return process.
If you haven't heard anything regarding the router being returned it could be with it being relatively new that BT/EE expect you to carry on using it with your new EE broadband.
You won't suddenly be landed with a bill for the router as BT in all fairness give ample warning that they want it back.
I really wouldn't worry because trust me when BT want it back you'll be the first to know.
As a matter of interest how are you finding the EE router in comparison to the BT device?
I received an email titled ' We need your kit back ' after my move to my new ISP. The returns label was an attached .pdf file which you print and affix to your parcel.
Very frustrating.
Look at instructions and it says send text to 61996 with word LABEL. Asks for email address but says doesn't understand that ring 0330 1234 150.
Rang 0330 1234 150 and it then says text sent. After long virtual process had chat discussion with Guide who said he would email QR code. Yes, I've checked junk.
Tried phoning again and went round in circles.
Hi @GeoffS471
Welcome to the community.
I appreciate how disappointing it is when you have tried everything suggested.
As router returns are handled by BT, I'd recommend Contacting our guides and advising them that the promised QR code has not arrived. If possible, ask them to confirm the email address they have recorded and request that the QR code or returns label is reissued.
I appreciate you've made every effort to follow the process and hope this can be resolved for you quickly.
Thanks.
Ritu
