Message 1 of 3
Router Bridge Mode
I have seen this asked before but the reason I'm here is I have seen you can use a BT router is sort of a bridge mode were you disable a few settings, change it's IP and hook it up to another router via ethernet port 4. This works and all but it continues flashes as it doesn't have a proper internet connection.
I was wondering if it is possible at all to trick it into thinking it's connected to a modem or ont so it thinks it has a WAN and how the WAN system works on a BT router as other routers with WAN can be connected no problem.
2 REPLIES 2
Message 2 of 3
Re: Router Bridge Mode
Without a broadband input it will continue to flash, it is a locked down device unlike third party routers where the WAN can be configured.  Black duct tape is the answer.
Message 3 of 3
I understand that and that you can disable the lights in the hub manager. But I am just curious if their is a way to trick it or some sort of box that simulates a ONT or compatible WAN connection?
