Message 1 of 5
Smart Hub 2 Enable/Disable WiFi
How is this for a clear message:
I was sure but not any more!
4 REPLIES 4
Message 2 of 5
Re: Smart Hub 2 Enable/Disable WiFi
Doesn't anybody proof read any more!!!
Message 3 of 5
Hi @dqj999,
Thank you for highlighting, I'll see if I can find someone to get that corrected.
Thanks,
Paddy
Message 4 of 5
It actually makes sense and is correct. The admin setting is 'No' to disabling all WiFi which the pop up confirms by saying wireless is then available because WiFi is not be disabled. If this setting is to be retained and wireless is to be enabled, the pop up gives options of either Yes or No. What's the confusion?
Message 5 of 5
The confusion is whether the message refers to the pop-up or the setting itself.
Any normal pop-up would just have a cancel button.
