Message 1 of 12
Smart hub 2 problems Hub manager and adding wifi disk.
Two problems . Linked?
Using BT smart hub 2.  Hub wifi only.
1. Unable to access BT hub manager , via 192.168.1.254.
2. Unable to link/pair WiFi disk with hub. Tried ethernet link hub to disk. With and without powered disk. Standalone powered disk ,  flashes blue, no steady state.
I am considering doing a factory reset on hub.
11 REPLIES 11
Message 2 of 12
Re: Smart hub 2 problems Hub manager and adding wifi disk.
can you access hub manager using ethernet connection
Message 3 of 12
No I have not tried connecting PC to hub via ethernet instead of wifi.
But its worth a try.
thanks CLimjolly
Message 4 of 12
CLimjolly I have tried your suggestion, to be able to access my smart 2 Hub manager, b y linking my PC to hub via ethernet instead of WIFI.
But sadly without success.
Any other suggestions would be appreciated.
ps I still cant pair smart hub 2 to wifi disks .
Message 5 of 12
Try a factory reset.
Remember to turn off Smart Setup again afterwards.
Message 6 of 12
@Frosty75
Just checking, it is a black wifi disc that you have?
Message 7 of 12
Try a different browser or clear cookies
Message 8 of 12
Keith Yes, the wifi disk is black.
Message 9 of 12
Les, tried different browser. And removed all cookies. But no change ie. still unable to access hub manager...........
Message 10 of 12
licquorice
TRY a factory reset.
Thats one thing, i have been trying to avoid.
