Message 1 of 3
Wholesome wifi
Anyone know if there is a way to force 1 disc to use daisy chain connection
i have a disc in the garage that used to daisy chain to the kitchen but now last couple of months it connects to the main disc with a poor connection
2 REPLIES 2
Message 2 of 3
Re: Wholesome wifi
Hi, @jonlea they should daisy chain automatically if that's the best connection option. Can you try moving the disc in your garage and kitchen a bit closer to see if that helps?
If that doesn't work I'd recommend getting in touch by phone: 0808 100 6116 Monday to Friday 9.00am to 5.30pm, Saturday 9.00am to 2.00pm
By email: btconnectedhome@bt.com
Neil
Message 3 of 3
Re: Wholesome wifi
Thanks, I notice an option in the menu via the browser to choose daisy chain, but that still does not make the garage connect 😞 Something changed a couple of months ago. I will have a play more then call
