Message 1 of 5
Wi-Fi extender ethernet port
This may be a daft question but here goes - can I run a poe security camera from the ethernet port of my Wi-Fi extender disc (black one) rather than connect it to the hub?
4 REPLIES 4
Message 2 of 5
Re: Wi-Fi extender ethernet port
Neither device supply POE
Message 3 of 5
Thanks for the answer.
Message 4 of 5
If you use an external POE injector, you can connect to the disc rather than the hub if it is more convenient.
Message 5 of 5
I didn't know these existed, so thanks for the tip.
