Message 1 of 2
handset number
Any idea how to change handset number on BT4600 phone. It is supposed to be able to have five on the system. I bought a replacement for a failure - handset 4 - and the new one has decided it is handset 6 and I want to to make it 4 - which has been deregistered
1 REPLY 1
Message 2 of 2
Re: handset number
You will have to de-register the handset and re-register and it will take up whatever number based on how many handsets are registered.  If you have old handsets which were still registered when they were sent off or disposed of they will still have a number.
Only way round that one is to factory reset the hub (which will make the username / password what it was) and re-register the handsets in the order you want
