Message 1 of 3
http://btwhole.home no longer works
The other day I discovered the internet interface for the first time, it was quite interesting. At the time my mesh was disconnected from my main router for testing.
Now it's plugged back in, going to this address (on a device which is connected to the BT mesh) just goes to my router's web interface instead.
There must be an explicit URL I can use <ip address of primary hub>//something, does anyone know what it is?
2 REPLIES 2
Message 2 of 3
Re: http://btwhole.home no longer works
Just use the IP of the master disc to reach UI.
If you don't the know the IP, scan your network, plenty free software to achieve this, or you can also look in the router at connected devices.
It shouldn't resolve to your router, this is strange.
Message 3 of 3
Finding the IP is not always that easy from the router but it turns out mybtdevice.home does work - just not btwhole.home. Not quite sure but it works which is great - I needed to change the WiFi channel and you can't do this in the app (as far as I can see) only the web portal
