Message 1 of 3
hub 2 upgrade
Hello,
just upgraded to Hub 2 and my digital cordless phones are showing line cord error, I expected them to continue working until and if I installed the Digital Voice phone supplied. any thoughts/ ideas as to how I rectify this situation. TIA
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: hub 2 upgrade
Your copper phone line will have been ceased. You need to plug the base station into the back of the SH2.
Message 3 of 3
Re: hub 2 upgrade
Thanks for the quick reply,  I overthought the problem and did not realise that  the cable end from the master socket fitted into the green socket at the rear of SH2, all sorted now, many thanks
