Message 1 of 9
150 vs 300
Hi all,
I moved to BT from TT 15 days ago and i have the free speed boost which is giving me the speeds below, i don't need the speed and was happy with TT's 150 Mbps but if i drop to 100 Mbps the lowest limit BT guarantee it may be an issue, can i drop to 150 Mbps then move back if it doesn't work out?
Thanks in advance.
8 REPLIES 8
Message 2 of 9
Re: 150 vs 300
Full fibre isn't rate adaptive like FTTC, you will get the full speed, besides which, I very much doubt if you could tell the difference between 100Mbps and 150Mbps in the real world in any case.
 The 100Mbps figure is just an administrative figure.
Message 3 of 9
Re: 150 vs 300
Thanks that is the answer i was hoping for.
Message 4 of 9
Re: 150 vs 300
I've been on 150 FF for 12 months now.  Probably done more speed tests than ever before.  (Just curiosity).  151Mb/s down, 29Mb/s up every time.  Doesn't matter how many times I reboot the ONT.  Doesn't matter how often I reboot the router.  Does matter that I've changed router.  151 down, 29 up every test.  Solid as a rock.
Message 5 of 9
Re: 150 vs 300
Thanks, looks like 150 will do for me,  TalkTalks speeds were good so looking forward to BT's being the same.
Message 6 of 9
Re: 150 vs 300
Just for the record, that should have been "doesn't matter that I've changed the router".
Message 7 of 9
Re: 150 vs 300
Were you getting the same speed before switching router?
Message 8 of 9
Re: 150 vs 300
Yes, like I said, rock solid.
Message 9 of 9
Re: 150 vs 300
Thanks again.
