Message 1 of 12
900mbps full fibre only getting 300mbps
i have 866 link speed on my pc but only download between 250mbps and 300mbps how do i get like 900 mbps download is it the smart hub 2 router or is it a pc adapter problem
11 REPLIES 11
Message 2 of 12
Re: 900mbps full fibre only getting 300mbps
You need to use Ethernet not Wi-Fi. Paying for FF900 is pointless if you’re only going to use Wi-Fi. You could look at getting an AX router and AX adapter for your PC to improve the speed.
____________________________________________
BT FTTP 500/75 + pfSense + 4 x UniFi Wifi 6 Pro
Message 3 of 12
How are you testing the download speed - which site are you using?
How is your PC connected to the SH2, via WiFi or Ethernet, or Powerline adapters etc?
What is the configuration of your PC, does it use a HD or SSD etc? Make/model might help.
If using anything other than Ethernet your download speed is likely to be more limited.
Message 4 of 12
if i have full fibre 900 and digital voice can i use my old gfast slot for digital voice
can i install digital voice in the old gfast socket instead of in the back of smart hub 2 becuase im getting a 3rd party router instead of smart hub 2 router i have open reach modem and gfast socket just wondering if i can put my phone in old gfast socket will that be fine for digital voice
Message 5 of 12
ty got one coming today how do i install it with digital voice basically can i plug digital voice in gfast socket then plug my 3rd party router into modem will that work or does digital voice only work when plugged into back of smart hub 2
Message 6 of 12
Re: if i have full fibre 900 and digital voice can i use my old gfast slot for digital voice
if you have FTTP then the old master socket will no longer work and you need to connect phone to socket on back of hub and hub needs to be connected  directly to ONT
Message 7 of 12
so basically i have to set it up as a second router how do i do it if i want my wifi 6 router to have auto qos mino etc
Message 8 of 12
i guess i would have to disable literally everything but Lan internet on Smart hub 2 so disable dhcp firewall upnp etc
Message 9 of 12
You can try following these instructions on setting up a second router with a SmartHub 2:
https://community.bt.com/t5/Home-setup-Wi-Fi-network/Smart-Hub-2-and-Bridge-Mode/m-p/2307011#M203811
Message 10 of 12
It's the pc I put a new wifi card in it now getting the correct speed even got a asus wifi 6 router speed all good now ty for help everyone
