Message 1 of 7
BT Fibre / Xbox series X
hi, I recently upgraded to fibre 900 and was looking forward to faster download speeds on the Xbox series X
A wifi connection test to the router is showing a maximum of 85Mbs - way short of the 600Mbs on other devices
Is there I can do to resolve this?
Tags (1)
6 REPLIES 6
Message 2 of 7
Re: BT Fibre / Xbox series X
Are you sure your Xbox is connecting to 5ghz network not 2.4ghz
Message 3 of 7
Yes, showing as 5ghz in the Bt app
Message 4 of 7
Message 5 of 7
A notourious Xbox problem, try a google search for a resolution.
Message 6 of 7
Have spent the evening looking, nothing obvious applies to my setup.
is it a Bt hub or Xbox issue?
Message 7 of 7
Ethernet speed seems to be much much better than wifi speed for the Xbox: Ethernet vs WiFi Xbox Series X - Speed Test 2023 (turbospeedwifi.com)
But how close is your router to the Xbox? Those seem to be really low speeds for wifi 🤔 I have the complete wifi disc right near my Xbox and it shows nearly 200mbps. 350-400 if I use the ethernet cable connected to the disc instead! (On the 1 month fibre 500 speed boost)
