Message 1 of 7
BT Fullfiber not working as of this morning
Hi,
As of this morning my connection is no longer working. On my FF mini-box the "LOS" red light is constantly showing, and my connection does not work, either via ethernet or wi-fi.
Upon checking the line from outside to the minibox, it looks as though it might have been tugged/pulled without me realizing.
I've tried to report the problem, at first it says "Problem failed" - then I get a strange error on the site saying "We can't help."
So my question is, can anyone from BT here help me book a visit to fix the problem? I've tried everything I can think of, so I'm sure the connection between the minibox and the ff line has broke somehow.
Thanks.
6 REPLIES 6
Message 2 of 7
Re: BT Fullfiber not working as of this morning
Unfortunately non of the moderators have account access any more, so you will have to ring up and report the fault.
Message 3 of 7
Ok thanks.
Is there no way to report the fault online? (Contact us etc?)
Tags (1)
Anonymous
Not applicable
Message 4 of 7
Message 5 of 7
Tried that, here's what happens.
1. I click on report a fault.
2. I select 'Can't get online at all'
3. Says 'checking, will take one minute'
4. It then says 'We'll need to send an engineer to your home to fix this.'
5. I click on 'Continue to book slot.'
6. Then I get the error '
Sorry, we ran into trouble checking your service'
And I can't do anything further?
Message 6 of 7
@AntRWells
if you cannot get openreach engineer with links posted then you are going to have to phone CS 03301234150
Message 7 of 7
Yes I was able to book an appointment through contact us.
Thanks for the help everyone.
