Message 1 of 3
Re: Line Capped at 48.998 - line reset required
Hi
Hope you are well - suffering same problem again!
Are you able to assist?
Thanks in advance
2 REPLIES 2
Message 2 of 3
Hi David
Hope you are well - same problem has occurred again - are you able to request a line reset please?
It has been sitting at 48Mbps for the past 3 months where previously I had 2 years of 55Mbps after your last reset  so pretty sure a reset will resolve the problem. Details below
Firmware version:v0.43.01.15019-BT
Firmware updated:Tue Jul 9 13:52:28 2024
Board version:R01
GUI version:1.80 11_07_2023
DSL uptime:8 days,08 Hours11 Mins33 Secs
Data rate:9.997 Mbps / 48.998 Mbps
Maximum data rate:15.836 Mbps / 59.640 Mbps
Full Fibre (FTTP) Mode:On
Noise margin:9.5 / 8.1
Line attenuation:9.5 / 19.5
Signal attenuation:9.5 / 21.2
VPI/VCI:0/38
VLAN id:101
Modulation:
Latency type:
Upstream error control:Off
Downstream error control:Off
Data sent / received:7.2 GB Uploaded / 128.7 GB Downloaded
Broadband username:[email protected]
Public Wi-fi status:Activated
2.4 GHz wireless network name:BT-T7A5MH
2.4 GHz wireless channel:Smart (Channel 11)
5 GHz wireless network name:BT-T7A5MH
5 GHz wireless channel:Smart (Channel 36)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:On
Wireless:Disabled
MAC address:F0:86:20:13:FA:D0
Software variant:-
Boot loader: 0.1.7-BT (Thu Nov 30 09:45:22 2017)
Message 3 of 3
Hi @GeeBee1701
We've had some changes to the community support team, and we no longer have access to customer accounts.
I recommend checking our broadband technical help pages, or contacting our customer service team so they can try resetting your line again.
Chris
