Message 1 of 8
BT Halo 3/BT Smart hub 3 wont operate with a Vpn.
For info: On a call today BT advised Halo 3 using BT Smart hub 2 does not work with a Vpn
Odd since there is a Vpn setting in the hub manager.
As i have just upgraded to Halo3 I wont be able to use my Vpn in future
7 REPLIES 7
Message 2 of 8
Re: BT Halo 3/BT Smart hub 3 wont operate with a Vpn.
Halo is just a benefits add on, there is no technology involved.
Message 3 of 8
Seems like yet another BT employee needs a bit more training!
Message 4 of 8
So will it work with a Vpn? Do i just put vpn web site in the hub manager option?
Message 5 of 8
You don't do anything, just use your VPN.
Message 6 of 8
Ok thanks.Im not very tech savvy im afraid.
I have been using the Myonelinetv2 App on an android tv.
But since i got fibre connected yesterday i cannot get into the myonlinetv2  portal in the App.
I have been using it with a vpn with the standard ( non full fibre) internet before the change to full fibre yesterday.
Stumped as to why a change to full fibre would stop accessing the myonlinetv2 app.
It freezes when loading the app now.BT said no settings need changing when changing to full fibre
Message 7 of 8
Problem sorted.My error.
Message 8 of 8
Hi @stevebarker12,
Thank you for posting back to update the thread.
Thanks,
Paddy
