Message 1 of 6
Fttp
Hi I can't upgrade from fttp 300 to 900. No one seems to know why or says it's a capacity issue I can order 900 with every other company other than Bt. Talktalk, Zen, giganet, shell and Vodafone all can and it is definitely though a openreach line as upload speed is 110 I'm at a lost with what to do. I can't get though to the fttp team I have been trying for over a week.
5 REPLIES 5
Message 2 of 6
Re: Fttp
Enter your phone number and post results and see what is available
If you have digital voice need to use your address
Message 3 of 6
Re: Fttp
You will be on an legacy eci ont/headend, which has max speed of 330mbps, and no other isp will be able to offer you faster.
They may sell you a 900mbps package, but will be disappointed on install day with the max speeds.
see :- https://community.bt.com/t5/BT-Fibre-broadband/Unable-to-order-Fibre-900-ECI-issue-FTTP/td-p/2133666
Message 4 of 6
Re: Fttp
I've had 900 with Talktalk and was working perfectly fine address checker says I can't even get fttp despite having full fibre 300 with BT already.
Message 5 of 6
Re: Fttp
Can you post dslchecker results preferably using your BT phone number
Message 6 of 6
Re: Fttp
An ECI headend could explain the 330Mb max download , but could not explain why other ISPs  that are using the same headend can offer 900Mb , after all the CBT that serves your property is only optically connected to one OLT ( headend ) via a splitter , so optically they are identical to BT .
Its possible that the ‘cable links’  that connect the OLT into the various ISP ‘backhaul’ equipment are the limiting factor , that would explain why some ISP that don’t use the BTw backhaul can seemingly offer 900Mb, when BT cannot ( obviously BT as an ISP , won’t use the same backhaul as Talk Talk or Vodafone for example ) or it could conceivably be a legacy of replacement equipment ( ECI swapped out for a manufacturer that does provide 900Mb ( soon to be 1.8GB) ) but the internal BT records have not been updated to reflect this where other ISP’s have.
The problem really is , because you can only speak to the ISP ,  when  the issue is really an Openreach/ BT Wholesale one  ( or whatever BTw is currently called ) you will only ever get someone in BT interpretation of the issue , as you are not allowed ( by the regulator ) to speak directly to BT’s supplier .
Have you considered emailing chief executive office , the executive complaints resolution people may be able to delve deeper into this , whereas a regular customer service representative may come up against the regulatory barriers
