Message 1 of 11
BT Halo 3+and EE Hub
I currently have a BT Halo3+ hub and a EE Hub. I am in the process of having Full Fibre 100 installed. On the Order it states that I have to return the EE box. Is this correct? If so will I still have a guaranteed connection?
10 REPLIES 10
Message 2 of 11
Re: BT Halo 3+and EE Hub
have you retained the Halo 3+ add on with your new fibre 100 package
Message 3 of 11
Yes I have still got he Hub.
Message 4 of 11
yes but are you paying extra for the Halo 3+ add on?  have you checked MYBT to make sure new package includes Halo 3+
Message 5 of 11
Yes I have checked. I have had Halo 3+ for a long time, all that is happening that full fibre is being brought to my house.
Message 6 of 11
if package still includes the Halo 3+ add on then you should be able to keep EE device
Message 7 of 11
Thank you I will have a chat with BT.
Message 8 of 11
Hi @GH101, sorry for the confusion over the equipment.
Has your order completed?
If you log into your MyBT on the web does it show any equipment is awaiting return? Your homepage | My BT
Cheers
John
Message 9 of 11
Yes it says return the EE Hub. I have spoken to BT and they are saying I can keep the EE and ignore the return request - No Charge.
Message 10 of 11
The Order has as yet not been completed, waiting for Openreach and Engineer.
