Message 1 of 2
BT Hub 5 and powercuts
Should I turn my Hub 5 off at the back before a scheduled power cut of 1 hour or leave it on?
If left on will the Hub reset itself when power resumes?
Thanks for your help!
1 REPLY 1
Message 2 of 2
Re: BT Hub 5 and powercuts
If the power is just going to be switched off once and then switched back on, it doesn't matter either way.
If the interruption is likely to be more intermittent, then turn the hub off until the supply is stable to prevent DLM taking action. The hub just restarts without intervention if you leave it on.
