Message 11 of 19
Re: BT refusing to uncap connection (Not DLM)
I'm not at home ATM but as per the op my attainable rate is about 45mb, synced at exactly 35000kbit/sec currently
Message 12 of 19
Why does my attainable speed indicate the contrary?
Message 13 of 19
However, until the cause of the DLM banding is investigated and fixed, there is no point in a reset as it will just ened up being banded again.
Message 14 of 19
@Keith_Beddoe the op has an attainable rate of 45, not a predicted rate of 45M by the checker.
Anonymous
Not applicable
Message 15 of 19
@-Richie-wrote:
40/10 is the SLT for Essentials, there is no 35 cap
I obviously misremembered & stand corrected.
Message 16 of 19
@licquorice- Stats:
# xdslcmd info --show
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 10436 Kbps, Downstream rate = 43160 Kbps
Bearer: 0, Upstream rate = 9999 Kbps, Downstream rate = 35000 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 8.9 5.5
Attn(dB): 21.9 0.0
Pwr(dBm): 13.1 6.7
VDSL2 framing
Bearer 0
MSGc: -6 -6
B: 73 105
M: 1 1
T: 0 0
R: 6 14
S: 0.0666 0.3367
L: 9610 2851
D: 8 8
I: 80 120
N: 80 120
Q: 8 8
V: 5 1
RxQueue: 130 18
TxQueue: 26 6
G.INP Framing: 18 18
G.INP lookback: 26 6
RRC bits: 24 24
Bearer 1
MSGc: 90 58
B: 0 0
M: 2 2
T: 2 2
R: 16 16
S: 10.6667 16.0000
L: 24 16
D: 1 1
I: 32 32
N: 32 32
Q: 0 0
V: 0 0
RxQueue: 0 0
TxQueue: 0 0
G.INP Framing: 0 0
G.INP lookback: 0 0
RRC bits: 0 0
Counters
Bearer 0
OHF: 0 0
OHFErr: 1 18
RS: 2442173688 1947481
RSCorr: 34397 23809
RSUnCorr: 0 0
Bearer 1
OHF: 7010614 746606
OHFErr: 0 0
RS: 42063315 2382446
RSCorr: 9 22
RSUnCorr: 0 0
Retransmit Counters
rtx_tx: 74340130 574
rtx_c: 1222 18651
rtx_uc: 13 52131
G.INP Counters
LEFTRS: 0 264
minEFTR: 34999 9997
errFreeBits: 60119261 83399377
Bearer 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 3284352020 0
Data Cells: 984579997 0
Drop Cells: 0
Bit Errors: 0 0
Bearer 1
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 0 0
Data Cells: 0 0
Drop Cells: 0
Bit Errors: 0 0
ES: 1 6
SES: 0 0
UAS: 26 26
AS: 112610
Bearer 0
INP: 54.00 45.00
INPRein: 1.00 0.00
delay: 0 0
PER: 0.00 0.00
OR: 0.01 0.01
AgR: 35418.64 10034.33
Bearer 1
INP: 2.50 4.00
INPRein: 2.50 4.00
delay: 0 0
PER: 16.06 16.06
OR: 47.81 31.87
AgR: 47.81 31.87
Bitswap: 57395/57395 7342/7361
Message 17 of 19
SNRM 8.9 and exactly 35M,  definitely been banded by DLM.
Have you been getting drop outs of broadband, do you have a phone? Check for noise on quiet line test 17070 unless you are on DV.
Message 18 of 19
Love it when BT support frequently and outright lies to customers.
No noise on the line, connection stable. Can go weeks without a DC
Message 19 of 19
unfortunately your stats don't show anytime for system uptime or more importantly connection uptime.  you must have had connection problem with internet dropping or/and manual reset trying to improve connection for DLM to take action and put connection in banded profile
