Message 11 of 20
Re: Being told there is no fibre broadband at new house
As you are doing a BT Home Move you will get the same type of BB at the new property as the old, as long as it's available there. You only agreed to a new contract term as is required for a Home Move; everything else will be unchanged. Has there been any price change?
I assume you are on ADSL2+ at the old home & that's what you'll be getting at the new. This is confirmed by your BT Home a/c.
Anonymous
Not applicable
Message 12 of 20
I imagine the BS stands for something you won't find in dictionaries! 😂
Message 13 of 20
We are on a copper connection at the current property. It’s an renovated, Old Church, very rural.
I really do not want a copper line at the new place. How do I go about ensuring I receive Fibre there?
It is actually a little cheaper with the new hone move.
Message 14 of 20
It's in all my dictionaries!
Message 15 of 20
Even if you switch to Fibre from ADSL2+ you still have a copper line to the house from the cabinet. It's only FTTP that is Full Fibre with no copper line at all.
Message 16 of 20
A fibre connection will be much quicker than 2-5Mb download speed though, I assume?
So effectively they’ve lied, telling me there is no Fibre available for my property?
Message 17 of 20
Yes, much faster. The BTw table suggests you should get 60 - 80 Megs.
In effect, yes, there is FTTC there. Once you have moved you can request CS to upgrade you from ADSL2+ to VDSL there, at a possibly higher cost.
Message 18 of 20
you will move your existing adsl connection to your new home and once move completed then contact options team to upgrade to FTTC 0800800030
Message 19 of 20
Thank you, Sir.
Message 20 of 20
Thanks, again.
