Message 1 of 12
Broadband speed query
We have Fibre 1 and I'm looking to get a better deal. I'm confused about the speed we are projected to receive.
When I do a speed test, we are getting 49Mbs.  However BT and other providers tell us we can expect only 7Mbs.
What is going on here? Are they just being ultra cautious about their speed promises? Or have they got something wrong in their information about our address?
Thanks for any help!
11 REPLIES 11
Message 2 of 12
Re: Broadband speed query
No idea, but if you are getting 49 now you will get 49 with any new deal
Message 3 of 12
Thanks very much, that's good to know. So every provider can give us the same service?
Message 4 of 12
Yes, unless you move to Virgin, all will use the same Openreach network. Your speed is fundamentally governed by the distance from the green cabinet and the laws of physics.
What does the checker show for your phone number https://www.broadbandchecker.btwholesale.com/#/ADSL
Message 5 of 12
@licquorice
For info, zzoomm (no spelling mistakes)have built their own network, it's pretty new at the moment and, to the best of my knowledge, it isn't available nationwide yet but the intention is there
Message 6 of 12
Not sure which of these numbers are important! Thanks!
Message 7 of 12
You probably should check that the FTTC ‘cabinet’ has capacity for ‘new’ customers, and isn’t showing as ‘waiting list’ ,it could be the 7Mb prediction is because only ADSL is available for new customers, if you change provider you would be a new customer with that company , however if you have FTTC and are simply looking to negotiate a better price , it’s irrelevant, what speed you get now will be the same with a new deal , that is just an administrative change in BT billing , nothing to do with the equipment providing the service, it’s if you change provider when things could change.
Message 8 of 12
According to that, your line is capable of between 68M and 80M. Presumably you have fibre1 which is capped at 55M hence 49M speed test. No idea where the 7M figure came from.
You have chopped off the right hand portion of the screenshot, does it say 'waiting list' or 'available' for the top 2 lines?
Message 9 of 12
@Les-Gibson wrote:
@licquorice
So have a lot of other alt-nets, but they will all be full fibre not FTTC.
Message 10 of 12
It says available top two lines and in a lot of other lines too.
Does this mean we should be safe to move provider without losing speed?
I'd prefer to stay with BT but as an existing customer their prices are not really competitive.
Thanks very much for your help!
