Message 11 of 13
Re: Broadband speeds different on Win11 Laptops compared to Android Phones
Only if they are all set up the same.
I suggest you check your network card drivers are up to date.
Message 12 of 13
@frank_bough
Not running any VPNs are you or configuring different DNS settings for the laptops rather than using those defined by the router?
Message 13 of 13
Hmm, gone very quiet.
