Message 1 of 3
Broadband speeds
Online showing bb capable of 80mbps but when tested over WiFi only getting 11mbps at best. Can someone have a look at this please. Currently running at 3mbps
2 REPLIES 2
Message 2 of 3
Re: Broadband speeds
This is a customer help customer community forum and your post does not go to BT.
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
As WiFi is subject to so much interference you need to check your speed using ethernet connection
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 3
Have you tried a speed test through MyBT?
It gives the speed to the hub and then the speed to your device.
