Message 1 of 6
Broadband upload issue
Morning
I have been having a problem with upload speeds all of a sudden over the last 2 weeks download is fine but upload is average 00.10 have tried to reset router to see if that works no luck any help is appreciated
Product code:Hub
Serial number:+091298+2128008084
Firmware version:v0.41.00.07076-BT
Firmware updated:Fri Nov 17 11:46:10 2023
Board version:R01
GUI version:1.79 12_06_2022
DSL uptime:0 days,00 Hours49 Mins06 Secs
Data rate:18.759 Mbps / 79.838 Mbps
Maximum data rate:18.759 Mbps / 80.931 Mbps
Full Fibre (FTTP) Mode:Off
Noise margin:6.2 / 3.3
Line attenuation:10.7 / 17.8
Signal attenuation:10.7 / 22.1
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:41.8 MB Uploaded / 147.6 MB Downloaded
Broadband username:[email protected]
Public Wi-fi status:Activated
2.4 GHz wireless network name:BT-T5CM8X
2.4 GHz wireless channel:Smart (Channel1)
5 GHz wireless network name:BT-T5CM8X
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:On
MAC address:70:97:41:B8:F5:E5
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
5 REPLIES 5
Message 2 of 6
Re: Broadband upload issue
@Legend4uk
Welcome to this user forum for BT Retail phone and broadband customers.
Are you measuring those speed using a wireless connected device, or using a direct Ethernet connection, as the correct speeds are showing on the home hub?
Message 3 of 6
This is using WiFi
Message 4 of 6
Probably wireless interference, or another device using all of the upload bandwidth.
Try a speed check using a PC directly connected to the Home Hub.
Message 5 of 6
What I have noticed when I use a VPN the upload seems fine as soon as I turn off the VPN its virtually 0 upload again could it be BT throttling me
Message 6 of 6
BT do not throttle any connection.
