Message 21 of 31
Re: Broadband will not connect
Indeed.
A crystal ball would be handy
Message 22 of 31
It may help if you post a photo of the equipment you were sent and if you could confirm FTTC or FTTP, the latter makes all the difference
Message 23 of 31
you should have a confirmation email from BT showing the package you have purchased and with an installation date or/and an activation date
Message 24 of 31
How do i know what my home number is? I've tried calling my mobile but it doesn't recognise it, neither does it 19000 which apparently calls back your number
Anonymous
Not applicable
Message 25 of 31
Dial 17070.
Message 26 of 31
where is your phone connected?  if you have DV then needs to be in socket on back of Hub but without internet connection it will not work
Message 27 of 31
I would but the photo is "too big". How do I tell whether it's FTTP or not
Anonymous
Not applicable
Message 28 of 31
By posting details of the order that you've been repeatedly asked for but seem determined to keep secret...
Message 29 of 31
I would tell you if I knew.
All I know is I have a SH20A router, two cables, a box to plug it in and that it's not working .. that is it. That is all I know
Message 30 of 31
You placed an order, what did you order? You would have had a confirmation email of the order, what does it say?
It's like pulling teeth
