Message 1 of 7
Bt essential ?
Hi with the bt essential for people on benefits like job seekers allowance it says  "Browse, stream or video call on one or two devices at home" does this mean i can only use the service on 2 computers ?
6 REPLIES 6
Message 2 of 7
Re: Bt essential ?
@Dazraz there's no such device limit. The text is just saying for the average speed it should be ok for streaming on 2 devices at once.
Actual speed is dependent on your what bandwidth your line can support
Message 3 of 7
Re: Bt essential ?
Thankyou
Message 4 of 7
Re: Bt essential ?
It says 30-34 but i have been getting 36-44 does this mean with essential i could still possibly get 36-44mbps or will it cap to 34mbps ?
Message 5 of 7
Re: Bt essential ?
It won't change
Message 6 of 7
Re: Bt essential ?
Hi @Dazraz and welcome to our community.
Great advice given by both @licquorice and @jac_95 . Hopefully that has cleared things up for you.
Cheers
David
Message 7 of 7
Re: Bt essential ?
Thankyou - yes this has been very helpful
