Message 1 of 4
CRC errors and HEC errors online gaming issues
Just purchased a unlocked hg612 to view line stats.
Can see high number of CRC errors and HEC errors on download and upload which possibly explains why my gaming connection is so bad in previous posts. (Gaming feels unresponsive, nothing registers and feels like opponent is 2 seconds ahead of me)
can anybody help explain how to get rid of these errors? I never used to have any issues when I used to have lower speed and higher ping however ever since an engineer visited, changed wiring and something in green cabinet which made the speed increase and ping decrease I’ve always had the same issues for gaming.
im getting a download speed of 8mb yes I’m aware but it makes no difference whether I get 76 or 8, it’s the actual connection that’s causing me an issue
3 REPLIES 3
Message 2 of 4
Re: CRC errors and HEC errors online gaming issues
You can't get rid of the errors, any errors are caused by impairments to the line which require investigation by an engineer.
Have you checked the stats by telnetting into the HG612 rather than relying on the GUI figures which are supposedly not accurate.
Message 3 of 4
hi mate , did you ever get this resolved ?
ive had high CRC errors on 3 providers now and ive had issues exactly like how you described for the past 2 years .
Message 4 of 4
The answer is still the same as @licquorice  gave.
