Message 1 of 9
CSP cover replacement
Due to severe weathering the cover for the CSP on the external wall of my house has completly broken apart exposing the internal fibre  to the elements. How would I get this repaired ? would be OpenReach or is it BT I need to contact?
8 REPLIES 8
Message 2 of 9
Re: CSP cover replacement
The lid of a CSP is secured to the main body by two screws , and is a compression fit , so how did the lid become open and capable of being damaged by the ‘weather’ ?, if it were a recent install you could argue it was never secured at installation , but how long has this been installed ?, BTW , I don’t think the lid can be replaced separately, the entire CSP would need replacing, requiring the wiring to be removed from one CSP , reintroduced into the new CSP and re spliced.
It no doubt just aesthetics, there is nothing metal to corrode, although the lid should be in place to stop potential interference with the fibres rather than any adverse performance issues ( it would work happily completely submerged under water for example )
….if BT are your provider ( it’s not clear if they are ) you could try to report it , but under what guise, and would it be potentially chargeable ?, report it  to Openreach directly ?, the reporting form for damaged or dangerous OR ‘plant’ is normally Openreach plant sited on public property ( roads and footpaths where no individual is could be deemed responsible for damage ) not individual equipment on property where that individual can be deemed responsible if damage is more than reasonable wear and tear
Message 3 of 9
So it sounds like you are saying that neither BT or Openreach will deal with it?
It was installed many years ago as part of FTTP trial  and I would guess that the material that was used then is no longer used for the cover as over time it has just become brittle and effectively fallen apart. The cover has not been opened as such but about half of the cover face has face has just broken away . Shame I cant upload a photo to show.
Message 4 of 9
I’m not saying it doesn’t need attention, just that the process isn’t particularly clear ( and TBH , in most cases I would suggest it’s going to be more than simply wear and tear if a CSP is not intact ) , but , if BT are your provider, presumably the correct procedure would be to report it to them , the exact nature of the fault report is tricky , you may need to be creative, once you get a visit arranged and the Openreach tech is on site , no doubt they would replace the broken CSP with a new one.
TBH , if your install was part of a trial , the CSP may well be of a different design to those that are fitted currently.
Message 5 of 9
Hi @pomfrei
Welcome and thanks for your post!
I am sorry for the problems you're having.  I understand the CSP on your external wall has been damaged over time.  We'll pick up from here and check this out.  I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Thanks,
Robbie
Message 6 of 9
To update - I contacted OpenReach damage repair team who said they would send an engineer out within 4 hours. They did this and replaced the CSP cover with a new one which is of  a far more robust plastic than the material used in the original one. No hassle and top marks for OpenReach speedy response on dealing with this.
Message 7 of 9
Hello OP @pomfrei ,
My CSP is also cracked and this is one of few results that came up from a few searches. In your solution, how did you contact the OpenReach damage repair team? Did BT do this on your behalf? Did you go direct to Openreach?
Phone numbers and/or emails involved in the resolution would be useful if you have them to hand!
Thanks!
Benny
Message 8 of 9
@lbenson7
You are posting on a four year old thread so you may not get a response from the OP of this thread who as not been back on the forum since this thread started.
Message 9 of 9
I wouldn’t bother reporting it as, ‘Damage’ to the Openreach Damage Report Helpdesk. They’ll most likely not send anyone out and even if they did it’d be allocated to any Engineer so they may not be FTTP Trained, therefore not carry a replacement.
You’ll need to report a fault to your CP who in turn will, or should book an appointment for Openreach to visit and replace it.
