Message 1 of 4
Cable question
Is the cable that runs from the grey exterior box around the house and then indoors to the modem also fibre?
3 REPLIES 3
Message 2 of 4
Re: Cable question
Yes for full fibre it's fibre all the way to the ONT that is fitted inside your property
Message 3 of 4
Re: Cable question
Thanks 👍
Message 4 of 4
Re: Cable question
yes
