Message 1 of 8
Can’t get the TP Link TD- W9970 to work with FTTP
Hi,
I am having a trouble to get router: TP Link TD- W9970 work with FTTP circuit installed by BT.
Is there anything important I need to consider when configuring the router ?
thanks in advance
7 REPLIES 7
Message 2 of 8
Re: Can’t get the TP Link TD- W9970 to work with FTTP
did you use username
[email protected]  and password if needed BT
you need to connect ethernet cable from ONT to the WAN port on router
Message 3 of 8
@AleksRoze
It need to be configured in Wireless Router mode with the login details as posted by @imjolly
Bear in mind that its only a 100Mb device, so is not really suitable for FTTP unless you have a low speed package below 100mbs.
Message 4 of 8
I have tried it, but still have no connection.
does the router needs to be on DSL, Modem or Wireless mode ?
Thanks In advance
Message 5 of 8
@Keith_Beddoe  posted already wireless router mode
Message 6 of 8
Thanks In advance
Did you not read the previous message?
Message 7 of 8
Message 8 of 8
Hi @AleksRoze and welcome to our community.
Sorry you're having problems connecting your TP Link. Please follow the advice posted by the guys and let us know how you get on.
Cheers
David
