Anonymous
Not applicable
Message 11 of 43
Re: Cannot get Fibre Cable at property
There's an Address Checker tab at the top where you can enter a postcode.
You can look up a UPRN here.
Message 12 of 43
Yes very helpful thanks
Message 13 of 43
/Users/charlottecrewe/Desktop/Screenshot 2024-03-27 at 13.11.45.png/Users/charlottecrewe/Desktop/Screenshot 2024-03-27 at 13.12.08.png
not sure if this will open ....
Message 14 of 43
Use the camera icon in the toolbar to add the screenshot.
Message 15 of 43
No! Use the camera icon (Insert Photos) to upload the photo from your hard drive location you have shown above!
SORRY - DUPLICATED as already reported by another forum member! @licquorice
Anonymous
Not applicable
Message 16 of 43
@Charlotte5
You will likely need to convert/resize that image first as PNGs tend to be too big for the 300kb limit for uploads on this forum.
Message 17 of 43
/Users/charlottecrewe/Desktop/IMG_4189.jpg
Message 18 of 43
May be easier to simply cut and paste the text, for example
Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential UG Feed with no anticipated issues.
ONT exists with active service. No spare ports are available. Network is at capacity so a new ONT cannot be ordered.
WBC FTTPUp to 1000Up to 220--AvailableKCI2 Assure
Message 19 of 43
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Handback
Threshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date
High Low High Low
VDSL Range A (Clean) help 80 79 20 19 78 Unavailable Available
VDSL Range B (Impacted) help 80 79 20 19 78 Unavailable Available
G.fast Range A (Clean) help -- -- -- -- -- Unavailable --
G.fast Range B (Impacted) help -- -- -- -- -- Unavailable --
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install Process
WBC FTTP Up to 1000 Up to 220 -- Available 1 Stage
Other Offerings Availability Date
VDSL Multicast Available
Exchange Product Restrictions Status
FTTP Priority Exchange Y
WLR Withdrawal Y
SOADSL Restriction N
Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential OH Feed with no anticipated issues.
ONT exists with active service. No spare ports are available. A new ONT may be ordered.
As a fibre priority exchange, FTTP has priority over other products if available at the address
As a WLR withdrawal exchange, product restrictions apply
SOADSL is not restricted at the exchange
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
For all SOADSL services,the stable line rate will be determined during the first 10 days of service usage.
This site is in an FTTP priority area where FTTP is available but exceptionally SOGEA will also show as available to order but only at Non-Standard Premises (NSP) such as Hot site, Uninhabitable and Temporary locations. Migrations of WLR Solus (voice-only lines) is also allowed but only for SOGEA 0.5Mbps bandwidths. SOGEA 40/10 bandwidths order is also allowed.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
ADSL, ADSL2+ and SOADSL availability: If shown at FTTP or SOGEA premises,ADSL, ADSL2+ and SOADSL are not available to order due to WLR Withdrawal stop sell rules. CPs should order FTTP or SOGEA. Copper products are only available by exception.
Thank you for your interest
Message 20 of 43
That shows that the  address you have pasted the information from the checker for , already has FTTP installed , so either when presented with a list if addresses, you picked the wrong one , the main house and not the basement flat , or the main house residents when ordering their FTTP  service inexplicably used your address ( the basement flat ) instead of their own address, or there isn’t two addresses a  main residence and the basement flat , but one single address , and you picked the only one available because there wasn’t two to choose from .
This could  mean  the address doesn’t have two  official individual units within it , otherwise it would have two entry's, one for the main residence and one for your basement flat, or the data OR use is wrong or out of date.
Its possible ,  if this basement flat was only recently created/ separated from the main residence , and has been correctly registered as a separate dwelling with the appropriate authorities, so it has its own a separate entrance , has its own council tax account, and has its own utilities ( separate gas, water , electric etc ) then the Openreach records may be historical whereas the Royal Mail record is up to date ,  if this flat has existed for a long time , then it’s odd that it doesn’t have an entry on the Openreach database as that’s pretty much a ‘copy’ of the Royal Mail dataset , so it could be it’s an unofficial flat , it’s basically just a room within a building.
If you are convinced that the flat is a separate ‘proper’ address , and not simply a room or rooms to rent , then the Openreach records need to be corrected to match the Royal Mail , assuming the Royal Mail website shows two separate addresses , the main residence and a separate basement flat .
