Message 1 of 8
Cant get Fibre, but every other house can.
Hi,
The street I live on offers full fibre to every house but my address.  I currently live on the ground floor of a maisonette and I am limited to broadband essential. Is it possible to have BT install the full fibre?
It seems like maisonettes are excluded currently and I could understand if I was top floor but with ground access I don't understand why I couldn't get the better speeds.
7 REPLIES 7
Message 2 of 8
Re: Cant get Fibre, but every other house can.
If BT customer then enter phone  number and post results
Message 3 of 8
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability DateHigh Low High Low      VDSL Range A (Clean)
VDSL Range B (Impacted)
5840127.735AvailableAvailable
56.63511.77.232.4AvailableAvailable
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
33050--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) Availability DateWBC ADSL 2+ADSL MaxWBC Fixed RateFixed Rate
Up to 3--1.5 to 5.5Available
Up to 2--1.5 to 4.5Available
1----Available
1----Available
Other Offerings Availability DateVDSL MulticastADSL Multicast
Available
Available
Exchange Product Restrictions StatusFTTP Priority ExchangeWLR WithdrawalSOADSL Restriction
Y
N
Y
Message 4 of 8
As you can see the dslchecker does not show FTTP is available to you. Are you sure it is openreach that are providing the fibre and not an altnet.
Try a neighbour's phone/address and post results from checker
Message 5 of 8
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability DateHigh Low High Low      VDSL Range A (Clean) Crytalos_0-1689711760641.gif
72.750.118.71244UnavailableAvailable
71.147.218.210.939.5UnavailableAvailable
----------Unavailable--
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessWBC FTTP
Up to 1000Up to 220--Available1 Stage
Available
 Y
 N
 Y
Message 6 of 8
Try contacting openreach.  https://www.openreach.com/broadband-network/fibre-availability
Message 7 of 8
Although Openreach survey an area for FTTP , including all property types , they can omit ‘difficult’ addresses at the build stage , intending to include those later.
If you live in a maisonette, it’s possible that it’s considered a MDU ( multiple dwelling unit ) and they are not normally picked up at the build stage , or if there are issues like obtaining wayleaves /permissions from the building owner , freeholder, building management etc again reason enough to simply leave those addresses out of the build .
Generally speaking the existing method of providing the copper pair service is the method used to provide FTTP , so if it’s a telegraph pole , the FTTP will be overhead, if an underground ducted fee , that will be used for the FTTP service, issues can occur if the feed is a DIG ( direct in ground ) cable , or if the existing copper pair distribution is from an ‘internal’ distribution point (this is common with MDU )  , or external wall blocks often terraced business property like shops  .
If all the ‘regular’ property ( detached , semi detached, terraced but served from poles or duct ) have availability but  maisonettes like yours don’t , it’s probably a deliberate omission, not a mistake.
Message 8 of 8
You can use this Openreach form to ask why you can't get FTTP:
https://www.openreach.com/forms/fibre-broadband-availability---customer-form
My neighbour in a flat was initally not able to get FTTP but used the form and OR said there was a capacity issue due to not enough ports being provided in the CBT - after a few months they increased the capacity and my neighbour could then order FTTP.
____________________________________________
BT FTTP 500/75 + pfSense + 4 x UniFi Wifi 6 Pro
