Message 1 of 6
Connector box inside only has three lights showing instead of four ??
5 REPLIES 5
Message 2 of 6
Re: Connector box inside only has three lights showing instead of four ??
3 lights is normal
Message 3 of 6
You really don't want the LOS LED to light because that means Loss Of Signal.
Message 4 of 6
It’ll never have all 4 lights on, its not supposed too.
Message 5 of 6
Thanks for photo !    Mine look like that except the colour plug are different colour !
Message 6 of 6
The system can not see colour. The colours are only there to help/make it easy for people plug the cable into the correct sockets at each end of the cable ie plug the yellow cable into socked A and socket B.
