Message 1 of 4
Cost of Engineer to fix LOS
Hi,
We are having renovations done and concerned about snapping or breaking the fibre cable. We live in centre of Bristol. Is there a cost for an engineer to come out? And if so what is the rough cost of it? If there is a breakage, how much do they need to replace? Can you diagnose if it's a break in the internal cable or exterior cable to the house?
Thank in advance for any help.
3 REPLIES 3
Message 2 of 4
Re: Cost of Engineer to fix LOS
@timvanellemeet
It would be Openreach that do any repairs, and the cost would depend on how much damage was done, but a minimum of £130 would be a good starting point.
You can ask them to relocate their equipment, but this would be more expensive.
https://www.openreach.com/building-developers-and-projects/altering-our-network
Message 3 of 4
Thanks Keith. I will give them a call
Message 4 of 4
You may have to pay for a survey, but that cost is normally deducted from the final charge. You will have more choice about where you want things relocated to.
