Message 11 of 39
Re: DNS issues with Smart Hub 2
No worries. What’s your hub serial number?
Message 12 of 39
<redacted>
Message 13 of 39
Thanks, will take a look
Tags (1)
Message 14 of 39
Hi @harry161
I think I can see a problem with your hub and will pass the info onto the hub team.
I've restarted a few processes. Are you working again now please?
Steve
Message 15 of 39
Hi Steve, yes it's working now. so next time it happens should I just restart the hub, anything I can do to prevent it?
Message 16 of 39
Thankyou! Very much appreciated!
A reboot will work yes but not ideal for you! Let me get back to you once I've had a think and spoken to the team about next steps.
Steve
Message 17 of 39
Thank you very much, Steve. Yes it’s frustrating especially when I’m outside and don’t have physical access to the hub. I’m glad I could help.
Message 18 of 39
@Steve_M  Hi Steve, have you got a fix for this? It has happened twice in the past two week which is very annoying.
Message 19 of 39
I had exactly the same problem after changing to Full Fibre. A new hub is on its way.
Message 20 of 39
The other thread is about wifi. I have a wired connection.
