Message 1 of 5
Daily Connection Blip
We get a very small but annoying blip in connection every(?) afternoon at a similar time. It's only maybe 30secs or so, hence not a massive problem, but pretty frustrating!
I haven't logged them every day, as I sometimes forget and it's most obvious when on a video call. However the pattern is pretty similar:
- June 10 15:35
- June 13 15:38
- June 18 15:53
- June 19 15:53
- Jul 1 16:16
- Jul 8 16:16
Any suggestions on what might be causing this? I had attempted to open a chat with the support team but didn't fancy the 25 minute wait.
4 REPLIES 4
Message 2 of 5
Re: Daily Connection Blip
Is there an electrical device in your house that switches on or off at that time?
Message 3 of 5
No, nothing that comes to mind. I can't think of anything we have on a timer except the boiler, but that would then be the exact same time each day.
Message 4 of 5
There was another similar report a while back and it seems that a full factory reset solved the problem.
Message 5 of 5
Thanks, i'll give it a try
