Message 1 of 2
Fibre Installation
Hi,
I currently have BT Fibre and am switching to Home Essential Fibre 2  from Fibre Halo 3+
BT has arranged for an open reach engineer to install new equipment but do i need to if I already have a fibre connection
thanks for your advice
1 REPLY 1
Message 2 of 2
Re: Fibre Installation
If you currently have FTTC ( fibre to the cabinet ) and FTTP ( fibre to the premises ) is now available, the opportunity to upgrade you is taken if you change your contractual status , upgrade , downgrade, recontracting….so chances are although you have ‘fibre’ you are getting better version of ‘fibre’ and it requires you to be at home to have it fitted .
